Electric Fan
Posted: Fri Oct 02, 2015 7:51 pm
by b110sss
Can anyone recommend a decent quality electric fan suitable for the 1200? I'm guessing a 12" one would fit but I'v only got around 45mm to play with in terms of clearance between my radiator and the waterpump pulley.
Dave
Re: Electric Fan
Posted: Fri Oct 02, 2015 8:14 pm
by 68p510sss
Dave
With my 1600 I had the same problem with the water pump. I finished up using two smaller fans in front of the radiator.
I will give you a call soon. Cheers Andrew
Re: Electric Fan
Posted: Fri Oct 02, 2015 8:42 pm
by brocky41
Davies craig slim 10 inch? depth 50mm?
Can do through work
Re: Electric Fan
Posted: Sat Oct 03, 2015 8:09 pm
by 85_Z31
Dave i have some 10" ones you can use for mockup purposes.
I probably wouldn't use one though they are just cheapies , a davies craig from brocky would be much better quality unit.
Re: Electric Fan
Posted: Sat Oct 03, 2015 8:32 pm
by b110sss
Thanks Guys.
Dave
