Oil pressure after rebuild
Posted: Thu Oct 15, 2015 8:42 pm
Well i finally decided to fill my engine up with oil today.
Engine is still up on the engine stand,
Engine is a L14 has a brand new L28ET oil pump on it,
So i primed the oil pump and bolted it in place checking dizzy drive position,
I have turned the engine over many many times by hand with a socket on the front pulley, I am looking for oil to flow through the cam shaft but it never came though, So i unscrewed the oil pressure sender fitting to see if oil would flow from the block.
Nothing would come out of that port,
So next i pulled pump and it was still fill to the brim with oil. So i put it back on.
I then unscrewed the oil filter and oil went everywhere all over my floor. So i know at least that the pump has picked up oil and started to move it round,
Am i just turning the engine over to slowly with a socket and a ratchet???
I would love to be able to prove that i have oil flowing fully round my engine before i put it in the car,
I do have the option of dropping the engine off the stand and bolting a bell housing to it, The i can fit up the starter motor and turn it over with that.
Does anyone think that this is what i will have to do to get engine spinning quick enough to move the oil round?
Any ideas or advice will be much appreciated,
Thanks
Brett
Thanks
Brett
