810 180b headlight assesmbly
MONTY
Datsun Dreamer
Post by MONTY »
Ok so I've got to put my normal full beams back in instead of my aircraft landing lights :) :) for cert but I think I'm missing some clips or something
They just don't quite fit. Any one got any ideas or could check theirs for me please?
I've checked my Haynes manual and it shows nothing but my driving lamps have www clips
Lamps with clips (although they are spot welded to the lamp)
Housing:
Full beam lamImagep
torqued
aka: Adam
Re: 810 180b headlight assesmbly
Post by torqued »
I had this issue with mine, ( now this was a few years ago )
I think the issue was difference between inner and outer bulbs.
MONTY
Datsun Dreamer
Post by MONTY »
Hmmm cheers man I shall have a look at that don't remember taking the others out but def could be s possibility
tlssunny
aka: jesse
Post by tlssunny »
outer lights should have 3 prongs
and inner lights should only have 2
from my memory there is slight different mounting/alignment between the 2
MONTY
Datsun Dreamer
Post by MONTY »
Oh god I bet I've thrown the wrong one out hHaha
MONTY
Datsun Dreamer
Post by MONTY »
Forums for the win, thanks all was trying to put the non full beams in Ahahaha Image
MONTY
Datsun Dreamer
Post by MONTY »
Right just to finish this post of so it might be useful to someone one day..
Normal lights on the outer with three prongs.
Full beam on the inner ( 2 prongs)
The cups that holds the lamps are can be used on either side (but mount differently depending on the side)
Normal lamps have a different mounting pattern so you can't swap either cups or lamps from inner to outer
That should do it.
