Haven't gone this deep into an engine before, have replaced timing gear though.
I believe I have to remove engine or take the rocker gear off and remove the push rods in order to slot the new cam in? Tip upside down to get it in the hole? Any help or advice appreciated.
Also, I have a catch can set up and over the last 2 weeks it's over flowed with water? No oil. It's been cold, thought it may have been condensation until I checked the oil fill cap and there was nice white sludge on it. How long does it take for your guys catch cans to fill?
Coolant is slightly low, but it seems to sit at that particular point every time I top it up.
May as well just do the head gasket at same time as cam installation. Needs to happen quickly! Have double valve Springs to be ordered from Kelford.
Thoughts on the kvs14d valve springs by kelford? Has anyone ran into issues or had them break? $211 for a set.
