Bolts Bolts Bolts. HELP!! Strut to ball knuckle
Posted: Wed Jun 08, 2016 7:19 pm
by twin120ys
Having a real hard time sorting this one out.
These bolts have a round head with a flat part designed to sit against the flat bit on the strut when you tighten.
Basically the go between the two points as pictured, they seem to be a special diameter as I've got some m10 (I think) in there at the moment but they aren't aren't tight fit.
This causes my wheen alignment to go out each time I take the strut off.
Scott at Cockram has tried but had no luck, my best bet seems to be finding some second had ones.
Re: Bolts Bolts Bolts. HELP!! Strut to ball knuckle
Posted: Wed Jun 08, 2016 8:32 pm
by 510BRE
hey mate on the arm that goes between the outer tierod end and bottom arm balljoint the (spindal steering arms ) from memory there should be a raised ring on spindal steering arm around where the balljoint is bolted to spindal steering arm to locate the shock . but yours looks not to have this . and the only reasons i can think off is that some body has put different shocks to your spindal arm or the spindal arm has been changed and does not match your shock 100 % and this would be to correct a little bump steer .
Posted: Thu Jun 09, 2016 8:04 am
by tlssunny
I know what you are saying because the bolt is 10mm but the shoulder will be 10.2 or something like that, the only place you will get them now would be second hand hand. they look like b310 or b210 struts and they are the "small" version
I would be asking on the ministock facebook pages for some or hopefully some one on here can help, isn't there a guy named ian in nelson I think with a heap of b210s??? and theres a b210 wagon wreking on trademe atm
have you lost your ones or what?
Posted: Thu Jun 09, 2016 9:21 am
by beaver
Cole, I have some at home from memory which mmight work. I think one of them is stripped tho as I remember replacing them with bolts. Will dig them out this weekend.
I seem to recall my bottom arm/knuckle having a locating ring which held the strut in place so small play in the bolts didn't matter.
Posted: Thu Jun 09, 2016 12:33 pm
by twin120ys
tlssunny wrote:I know what you are saying because the bolt is 10mm but the shoulder will be 10.2 or something like that, the only place you will get them now would be second hand hand. they look like b310 or b210 struts and they are the "small" version
yup b210 struts 50mm large 120y ones. Yeah it's a funny size and as you guys are saying, there is a locating ring on the bottom of strut (it's circle) so it can still rotate sideways unless the bolt is the correct size.
My running gear for the 120y came from another car when I brought it years ago, and they were stripped badly so I put some m10 in there and have realized the issue with my wheel alignments finally...
I'll give Ian a go!
beaver wrote:Cole, I have some at home from memory which mmight work. I think one of them is stripped tho as I remember replacing them with bolts. Will dig them out this weekend.
That would be great Andrew, thanks. Ron Clifton is also checking his shed for me this weekend
I suppose everyone else's bolts just haven't stripped yet?
Posted: Fri Jun 10, 2016 7:12 pm
by taiparacer
Found box with bolts in
