Blown head gasket? L18
Posted: Wed Jul 20, 2016 9:21 pm
Well......
After fixing the problems with the SU's due to an air leak around one throttle shaft I have taken it out on the road and have found that it is using water - no, it doesnt have water injection (or at least a proper system) but about 2L disappeared from the radiator. Maybe it ran lean on 3 or 4 and overheated/ blew?
Ive checked the oil and theres no milkshake so Im thinking that the gasket has failed between a piston and a water gallery and that its just blowing through when it gets warm. There didnt seem to be much pressure in the radiator after it was run.
So unless its going somewhere else it looks like Im off to BNT or someone similar to get a full gasket set, timing chain? (and probably water pump too) and pull the head off. Is there any way to leave everything set up so that it can slot back together, or does it need to be reset to TDC and get the cam indexed? The other options would be to have the engine rebuilt to make sure that engine and head are good, does anyone have any recommendations for someone to rebuild the engine (from Auckland to Taupo - dont mind a drive for a couple of hours). Or does someone have an L18 out there that theyre not using? (I think an L20B just falls outside the increase in CC rating without getting a cert).
An ideas/ help greatly appreciated.
Thanks
Thanks
