Im Slowly figuring out how to get the photos right- haha
I have a bunch more that will get me up to date.
I pulled the brakes a part to check the condition and wasn't quite happy with them. As you can see there is some wear through the hardened layer.
Heres the assembly parts...
Oh well, guess I had better upgrade the brakes then right??
I tracked down some brakes off trade me... unfortunately the seller neglected to mention that the rotors were rooted, so I had to buy a new set.
heres a comparison with the Datsun 1200 hubs and rotor, compared to the new rotors...
Off to the neighbours to machine down the hub so the rotors fit over the hub..
Heres when I made the big mistake of painting everything before making sure everything would fit....I figured with the caliber brackets etc its all bolt on as per the forum info-but this was not the case..
All painted in heat temp paint and clear gloss..
The caliber brackets I bought either have the calliper bolt holes 5mm too low or my callipers are slightly different to what they should be...
The round piston housing hit on the curve of the bracket and the bolt mounts on the bottom of the strut would hit the casting edge on the calliper mount. This took a lot of work to get the tolerances right without sacrificing the integrity of existing components. I should have just made new brackets and re drilled the holes 5mm higher... you live and learn.
all done now and ready for dismantle and paint.. again...
Im swapping the struts from left to right so the callipers are on the forward side of the rotor. It makes sense and gets everything away from the steering...
