L16 inlet/exhaust gasket problems
Posted: Sun Nov 17, 2019 7:37 pm
I've got a real hassle here, the gasket has now failed twice and is leaking out the bottom of the exhaust ports past the gasket. After the first failure I got the exhaust manifold surfaced as it was a little out of true against a straightedge. I then used a gasket from APPCO and installed it dry. This began leaking after just a few hundred km.
What do I do, experts? Do I need a genuine gasket which looks thicker than the APPCO one including the reinforcing around the exhaust port holes. And, what sealant do you recommend, bearing in mind both inlet and exhaust ports are mating onto the same gasket including water port holes for the inlet manifold.
Next question is where can I find said gasket, in NZ or do I get one from Oz or the US, or eBay?
I'm keen to get the car up and running over summer after sitting for a little while now, about nine months!
