Driveshaft for 60a to 410/411 H165
all your DIY needs
jeremiahnz
Datsun Driver
Post by jeremiahnz »
Hi guys,
Yep, more q's from me...
I'm looking for a driveshaft which has the correct splines/yoke to go from a 60a to a H165 diff. I believe a 1200 ute driveshaft does exactly that, but just aren't sure about the end flange as my H165 is from a 410/411.
I have attached a picture of the flange below. The dimensions are roughly 73mm x 64mm. From looking at http://datsun1200.com/modules/mediawiki ... haft_Swaps" onclick="window.open(this.href);return false; this looks more like the H150 however the dimensions of that seem too small. The H165 flange pictured on that site is completely wrong for my diff (round), however I guess there could be other models.
Does anybody know if there is a driveshaft that can go from a 60a to this H165 flange?
BTW the J13 and E1 driveshafts have different spline patterns for the gearbox, neither of which work with the 60a
Also, if anyone in AKL has a driveshaft with a 60a spline that they are willing to sell please let me know as I may have to get one cut down and welded to one of my 410 driveshafts.
1965 Bluebird 410
1976 Yamaha RD50
mint16
aka: Brendan
Re: Driveshaft for 60a to 410/411 H165
Post by mint16 »
ive got a spare 1200 ute two-piece driveshaft if that interests you.
72 Datsun 1200 Wagon
jeremiahnz
Datsun Driver
mint16 wrote:ive got a spare 1200 ute two-piece driveshaft if that interests you.
Yep, could be keen if shipping isn't too much. Does it have a round flange on the diff end or rectangular?
1965 Bluebird 410
1976 Yamaha RD50
mint16
aka: Brendan
Post by mint16 »
rectangle.
I'm 90% sure that the B310 suny driveshaft fits an H165. (The ute variety) It's only the H145's that were different. But being so old Yours may be oddball again. Can you measure the diamater of the yolk flange spigot?
jeremiahnz
Datsun Driver
mint16 wrote:rectangle.
Cool - that may work, any chance you could measure the flange dimensions, the OD of the yolk flange spigot and the bolt pattern?
1965 Bluebird 410
1976 Yamaha RD50
jeremiahnz
Datsun Driver
Bartman wrote:I'm 90% sure that the B310 suny driveshaft fits an H165. (The ute variety) It's only the H145's that were different. But being so old Yours may be oddball again. Can you measure the diamater of the yolk flange spigot?
Here are some more pics which should give a better idea of dimensions. The OD of the yolk flange spigot is around 55mm
Pic with general measuremeants and bolt holes:
Pic with OD of flange spigot
1965 Bluebird 410
1976 Yamaha RD50
Dattodevil
Datsun Addict
aka: Damo
Post by Dattodevil »
Vanette driveshaft from H165 might be an option too
oh hey,
don't get too caught up in the flanges matching. In my car atm I have a round tal shaft yolk flange bolted to a rectangular diff pinion flange.
When I get the chance I'll measure my sunny d/shaft flange and let you know if that'll fit.
