grrr webers aint fitting this is ass
fattydattypopo
- Newbie
can anyone tell me if im going mad or not, bought manifold to fit dual weber sidedraughts, checked it out and could not believe it when to my luck they wont fit, studs fit perfect but choke plate at rear and throttle shafts wont, bit more than a fly shit out..
datsunboy
- aka: Dan
Re: grrr webers aint fitting this is ass
well, for a start, they're meant to have a spacer/isolator thats maybe about 8mm or so thick, that goes between the manifold and the carbs......but im not sure that that would solve your issues
dirtyleppa
- aka: leppa
dude, that sux real bad
how could it be so wrong, yet so close?
- Brnwgn
- aka: Hayden
yea spot on dan u shud never mount them ridged, but it doesnt look like the right manifold anyway as the carbs are very close maybe the manifolds for 38's not 40's, i have in the past cut the throttle shafts and fitted thinner washers behind the nuts to allow for clearance... that maybe an option. jus file or grind the piece in between to allow clearance for the throttle arm thingy.datsunboy wrote:well, for a start, they're meant to have a spacer/isolator thats maybe about 8mm or so thick, that goes between the manifold and the carbs......but im not sure that that would solve your issues
fattydattypopo
- Newbie
yeah knew there was o-ring seal but not about spacer, check measurements again
fattydattypopo
- Newbie
photo off trademe, this guy must have succeeded his look pretty crammed together, looks similar size to my manifold.
