why does my passenger light blow
sunny79datto
my passenger side round headlight always blows randomly on low beam..dont know why the wiring is to hard to trace for me but hadnt done it for ages an now done it again... any ideas?
- Dattodevil
- Datsun Addict
- aka: Damo
Re: why does my passenger light blow
Are you running the sealed beam headlight or is it H4?
Gidday, Check the earth wire is screwed up tightly and rust free, test and compare voltage at battery positive left and right light feeds, My advise is to add relays and ensure a decent earth, adding relays will usually give you an increased light output, especially on older vehicles!
Driven At Top Speed Until Nackered
http://www.raeltdmorrisjvan.blogspot.com/" onclick="window.open(this.href);return false;
http://www.trademe.co.nz/Members/Listin ... ber=572504" onclick="window.open(this.href);return false;
sunny79datto
yea sealed beams.. an yea will check my earths when i track the wiring down the guy who had my car b4 me looks pretty rangi on the wiring n its all taped up. how would i put relys in it?
It's not hard
You just need to by a couple of relays, and the wiring is pretty easy. Dan or I could prolly draw you a diagram. I have a workshop manual with a daigram to start with. The rest isn't hard
interesting, the drivers side high beam on my 1600 blows about once a year too. And the interior light in the work ute always blows after a week or so, sucks when you start work in the dark!
- Dattodevil
- Datsun Addict
- aka: Damo
If you use an argon filled interior bulb, it lasts much longer.nzdatman wrote:interesting, the drivers side high beam on my 1600 blows about once a year too. And the interior light in the work ute always blows after a week or so, sucks when you start work in the dark!
never heard of them, will look into it, thanks damon
