B310 Sunny Shocks - stressing me the hell out
all your DIY needs
Josh
aka: SeEn-ThE_lIgHt
Re: B310 Sunny Shocks - stressing me the hell out
Post by Josh »
Im rollin' 212mm
1972 B110 Deluxe~ Daily
1965 P410~ Wifey daily
grant76
Datsun Nutter
Post by grant76 »
you've got the baby's then, need b110/b210 inserts. B310 would be way to big which hopefully explains your problem??
Josh
aka: SeEn-ThE_lIgHt
Post by Josh »
So ring supplier, pretend ive got a B110 Sedan and see what happens?
grant76
Datsun Nutter
Post by grant76 »
worth a go (If they dont fit, send 'em back). Chucking some gas inserts in is less mucking around than cutting/lathing/re-threading etc.
I had a sunny once that steering arms with the 1200/120y bolt spacings. (Still had the larger 310 ball joint tapered hole though) FWIW
fast4motion
Datsun Dreamer
aka: Brent
Post by fast4motion »
What a lot of hassle just for a pair of shocks!
If you had a square headlight model (with the larger, stronger struts) there'd be no need for all this drama. Your new inserts would've slid straight in, and you'd be cruising in style, using your old inserts to fend off all the babes that'd be gagging for the square headlight sexyness. :poke:
datman310
Post by datman310 »
fast4motion wrote:What a lot of hassle just for a pair of shocks!
:agree: :highfive:
nick_m
Datsun Master
aka: Nick m
Post by nick_m »
If you've got 45 OD struts use EP71 KYBs, same (or near enough) length as mk1 golf inserts except you can actually get them
They are real short, you'll need to cut down the strut tube but if you want slammed you'll need to do that anyway. Other not so slammed option is n13 (i'm pretty sure its n13, might be n12) they are about 75mm shorter than stock
mint16
aka: Brendan
Post by mint16 »
my 79 round headlight sunny wagon has the larger 51mm struts.
the first of the round headlight sunnys may have received the same struts as the late b210 120y's, that used the larger steering arm bolt spacing but the 45mm strut.
72 Datsun 1200 Wagon
