clutch slave
king_josh_the_2
- Regular
- aka: Josh
clutch slave
anyone know if the clutch slave from a L series is the same as a Z series one ? went to bleed my brand new 1 last nite and mate pumped it and the rubber and pin shot out and pissed the fluid everywere so was thinking it might be to small as its not touching the clutch lever
Z18ET 1600
510BRE
- Area Reps
- aka: shane
Re: clutch slave
i know that s14 silvia is same as L series
Re: clutch slave
I know that Z series clutch forks are just a tiny bit longer than L series ones.
king_josh_the_2
- Regular
- aka: Josh
Re: clutch slave
it seems like its further away from the slave as it just shot out before it was pushing the fork should there be a circlip or hoseclamp type thing holding it on there? ill try get some pics up tomorrow
Z18ET 1600
dirtyleppa
- aka: leppa
Re: clutch slave
generally there wont be a circlip holding the pushrod in. normally, its just the rubber boot that holds it in place
510BRE
- Area Reps
- aka: shane
Re: clutch slave
if it is the issue off the push rod coming out what you can do is take out gearbox and put a couple thin washers under the pivot for the clutch fork
king_josh_the_2
- Regular
- aka: Josh
Re: clutch slave
sorted today after talking to Mikewazowski ended up going to repco and getting a clutch slave for a 180b and it fits mint
Z18ET 1600
Re: clutch slave
good to hear man.
