Ok I'm looking into brake lines for the J what i want to know is the back lines are they the same as some other Datsuns Nissans I've got front struts from a r 31 so would like to try and get a set for a R31 but hope the back would be the same my rubber one's are shot was going to try to get some on the cheap as always
And i have done a search on here and other sites here and ozzy and usa but came back a blank
Stainless Steel Braided brake lines
- 160jsss
Violet - ??????
Re: Stainless Steel Braided brake lines
CV specs do custom made ones that are wof compliant but good luck dealing with him
- 160jsss
Yes been and seen him before he wants $200 a brake line so they will stay there .
If i knew if r31 IRS rear ends where the same I'd just get a set of them Trademe has then for $200 a set so i should get them cheaper through work if not is the good old rubber ones
Violet - ??????
- aka: leppa
for a road car, new rubber ones would be more than enough, while still being cheap. if you do want braided lines try safe r brakes, but they can also be a bit of a pain. i would personally go through undercar and commercial in hornby. they do good quality work and are generally cheap. they can do both certified rubber and braided hoses.
be aware of the ones on trademe as they may not meet NZ standards and could be a waste of money
- 160jsss
They say they meet DOT standards i thought that was sweet with VTNZ ???dirtyleppa wrote:be aware of the ones on trademe as they may not meet NZ standards and could be a waste of money
I had braided lines on my old 180b don't know if it was because they were shiny but i swear i could tell the difference .
Good brakes beats horse power in the twisty stuff and i wont have lots of horse power
Violet - ??????
I believe they not only have to be DOT compliant but also meet the standard of MVS 102 something or rather
and each hose has to be labeled with it to pass wof
if you have a read of the WOF VIRM online it pretty much tells you all you need to know.
- aka: Nick m
basically if they are plastic coated they are geberally sweet. You can't have uncoated braided lines as they can fray.
160jsss wrote:Yes been and seen him before he wants $200 a brake line so they will stay there .
- 160jsss
Shit maybe i misheard him and that was 200 all up that would make me a deaf muntertorqued wrote:160jsss wrote:Yes been and seen him before he wants $200 a brake line so they will stay there .his usual retail was $70
Violet - ??????
