SSS wheel nuts.
Dattodevil
Datsun Addict
aka: Damo
SSS wheel nuts.
Post by Dattodevil »
Got some 12" wards SSS wheels and need a full set of wheel nuts, they seem to be shank type with taper, probably 19mm hex. Anyone got any picks or can supply?
MR1200
Datsun Nutter
Re: SSS wheel nuts.
Post by MR1200 »
ring nice products aka davie holden in auckland they have every nut you could think off its where i got mine from
PAINT THE ROADS BLACK !!!!!
torqued
aka: Adam
Re: SSS wheel nuts.
Post by torqued »
Your friends down the road damon stock "nice products" also . think they are a chch supplier
Dattodevil
Datsun Addict
aka: Damo
Re: SSS wheel nuts.
MR1200 wrote:ring nice products aka davie holden in auckland they have every nut you could think off its where i got mine from
Will do, cheers
torqued wrote:Your friends down the road damon stock "nice products" also . think they are a chch supplier
Haha, I don't think so :D
Re: SSS wheel nuts.
The SSS wheel nuts are unique. They're halfway between a shank nut, and a conventional lug nut.
Simon (TL motorsport) has most of a set. Perhaps he could give you the loan of one as a sample? Or to have one made from?
braasmonkey
Site Admin
aka: Braasy
Re: SSS wheel nuts.
Post by braasmonkey »
Bartman wrote:The SSS wheel nuts are unique. They're halfway between a shank nut, and a conventional lug nut.
Sounds like a good idea. They're actually for me. Have been struggling to source so will touch base. Do you have contact info? Cheers.
Dattodevil
Datsun Addict
aka: Damo
Re: SSS wheel nuts.
Would that be TL Speed Shop?
braasmonkey
Site Admin
aka: Braasy
Re: SSS wheel nuts.
Dattodevil wrote:Got some 12" wards SSS wheels and need a full set of wheel nuts, they seem to be shank type with taper, probably 19mm hex. Anyone got any picks or can supply?
Purchased full set plus socket for $90 incl GST from Mag & Turbo. Look much better than the things holding the wheels on originally :)
Dattodevil
Datsun Addict
aka: Damo
Re: SSS wheel nuts.
Do they fit?
510BRE
Area Reps
aka: shane
Re: SSS wheel nuts.
Post by 510BRE »
um appco use to do a good range off wheel nuts ...do use have appco in the south :poke:
