Datsunboy's KP510 SSS Bluebird coupe
datsunboy
aka: Dan
Re: Datsunboy's KP510 SSS Bluebird coupe
Post by datsunboy »
took a pretty cool pic of it parked up at the hilltop on the Akaroa cruise 8-)
datsunboy
aka: Dan
Post by datsunboy »
spent my labour day today working on the coupe 8)
First off, I started looking at tuning the carbs, but decided to strip them down, clean them up and do it properly.
Chokes are still sticking a lil bit, but not as much as before......I'll leave them disconnected for now lol.
got them all back together, then used a flow meter I borrowed off Damon to sync them,and then put the wideband O2 sensor on, and adjusted it to as good as I could get it.....then took it for a drive.....pretty good!
it sits at 12.2:1 AFR through the gears when I took it for a blast down the motorway near our place. 8)
and sits at about 15.2:1 AFR at idle.
reason for this was, it was running REALLY rich, and fouling the plugs up on the Akaroa cruise....used almost 3/4 tank haha.
then after that, I put on my new grille I scored off adam 8) (same as my old one, but in MUCH better condition).
then installed my bonnet vents (finally.....Ive had them almost a year....nothing like a 31 Datsun cruise to raise some inspiration!)
datsunboy
aka: Dan
Post by datsunboy »
pic!
torqued
aka: Adam
Post by torqued »
tuff....very tuff....
and my thoughts excatley ..nothing like the hard work of others to inspire you to do some yourself..
sitting in the pasengers seat of the cruise all i was thinking about was getting my car onto the next one
datsunboy
aka: Dan
Post by datsunboy »
well, I finally found a Air con pump and bracket for the coupe!
bought it last night from a Z20, and it bolted up sweet as! (I had assumed a Z AC pump would fit an L block)
now I just need to buy a shorter V-belt for it, and get a condensor (AC radiator) and get it piped and gased up!
anyone got any old AC radiators/condesors they dont want?
I have tried a 260C one.....but its too big
sssx
Regular
aka: adrian
Post by sssx »
iv got an ac radiator out of a 910 bluebird lying round somewhere if your interested
datsunboy
aka: Dan
Post by datsunboy »
can you give it a quick measure up for me? LxWxD?
then I can see if it'll fit 8-)
sssx
Regular
aka: adrian
Post by sssx »
520x320x20. iv got all the pipes from it too
not the best condition. ill take a pic if its going to fit
datsunboy
aka: Dan
Post by datsunboy »
cheers!
will have a quick measure up when I get home tonight 8-)
datsunboy
aka: Dan
Post by datsunboy »
hey man, that 520x320 sounds like a perfect fit!
what do you want for that stuff?
