Re: Datto_610's 180B
I beleive he's running 910 struts Martin. He's working of the how-to here http://www.datfusion.com/forums/index.php?showtopic=129" onclick="window.open(this.href);return false;
- Datto_610
- aka: Greg
Bart ill need to be able to put some kind of wheel on the front to move it round and get it off the stands and stuff.
Martin im running 910 struts got the cad drawing for the brake conversion off ozdat too.
Dattochriswagon
Also as another point of view. If you have the wheels you want you build your car around them to ensure you dont run into problems after you have certed your car and you have to put spacers and modify arms/struts. camber tops.
Ive done that with my wagon and also John has done so with his cedric(even tho he changing his wheels and suspension again)
They can cost heaps or very little. I seen some Mk2s that im mad for and they were only a couple hundy.
- Jaimesix
- Regular
Howzit.Dattochriswagon wrote: Also Jamiesix. Your wheels measure 9 inch with the ruler but they are 14x8?Just a observation
Like Dirtyleppa said, as far as wheel width concerns, it is measured between lips. The inner side of the lips. That is the area on which the tyre will be mounted, the area the tyre can expand. The extra 0ne inch width ( 1/2 in on ea side ) is what the lips thickness is all about. ( 1/2 inch each side )
A nine inch wheel would measure 10 inches across.
Cheers.
Datsun 610/180B
Datsun 710/140J (L20B)
Mazda RX7 FD.
Suzuki Samurai/Sierra.
Honda CB750F DOHC..
Mazda RX7 FD.
Honda CB750F DOHC..
- Datto_610
- aka: Greg
More progress!
Today i finished greasing and assembling my rear axels, borrowed some factory Laurel mags off Bart which cleared the spring by having the brake rotors on to space them out a bit. Also got the crane in position to take the motor out when i get my stand back, which should be this week. Im going to have to jack the car up again so i can fit the legs from the crane under the car to get it a bit closer. Radiator as been modified had to go remote resovoir so the bonnet would sit nice and tabs have been welded on to make mounting easier. Might also need to go for longer springs in the front too so they stay captive.
Heres some pics:
Heres some pics:
- Mikewazowski
- aka: Michael
Good news! Can't wait to have another member in the boosted 610 club!
Godzilladat
The cv's look swwweet, what diff are you running again?
Also really like those wheels in black.
<-- in no time.
- Datto_610
- aka: Greg
Thanks guys!
Ill be running an R200 VLSD Martin. Just need to find and buy a lsd center for the diff.
datman310
looking good mate , great to see progress and cant wait to see this bad boy on the road
Dattochriswagon
