lots of CA18 stuff for sale
Sell stuff
nzdatman
Post by nzdatman »
After collecting all this stuff over the years, I've finally come to the conclusion that I'm just not going to get around to it so need to sell this stuff so I can walk around in the shed again.
All non-turbo stuff, was going to build an NA CA18 for my race car but now have other plans.
3x complete CA18DE engines, $300 complete with wiring and ecu or bare engine $150 ea, one probably only really good for parts $free,
1x CA18DE in parts, have flywheel clutch etc
2x CA18 gearboxes, 1 is an S13 $200, 1 is S12 $150, plus one S13 box in parts that I was putting into a navara housing to make a short box with the late model shifter, or you could put it back toghether as standard S13, this has some new bearings to go with it $150
1x CA18DE sidedraft manifold that I made, has the butterflies for the TVIS or whatever it is called removed and plugged up, suits 45mm DCOE/DHLA includes new studs $100
2x JASMA extractors both probably wont fit a datsun without some modifying,nice etractors though $125 ea
1x quick shift gearlever to suit the S13 box (new) $50
1x pr adjustable cam pulleys (new, may suit RB too not sure) $100
1x CA16DE head which I was going to use the cams out of (slightly bigger) $50
CA18DE auto bellhousing that I kept to adapt to another gearbox but didnt $20
various ecu's wiring looms etc
was going to run ignition with distributor, started modifying a dizzy to run where CAS goes,
as well as other bits and pieces.
If one person wanted to take the lot that would be ideal but I realise it's unlikely so if not I will sell the bits off, would prefer the wiring stuff to go as complete conversion with engine but will split if no joy.
Can take photos if need be. Will be on here a few days then will start puting it on trademe.
nzdatman
Re: lots of CA18 stuff for sale
Post by nzdatman »
by the way if any of the prices I put up are out of touch with reality just let me know. I don't really know what the stuff is worth and would rather get rid of it that hold out for ages for top dollar.
I wish you were closer, and I had more coin. :deadhorse:
nzdatman
Post by nzdatman »
some pics up. what are you keen on Bart?
nzdatman
Post by nzdatman »
up on trademe now. $500 take the lot.
http://www.trademe.co.nz/Trade-Me-Motor ... 117126.htm" onclick="window.open(this.href);return false;
nick_m
Datsun Master
aka: Nick m
Post by nick_m »
Will you take $40 for side draft manifold.
Don't know what the fuck i'll do with it. But figure it might be handy lurking in the shed for a rainy day :D
nzdatman
Post by nzdatman »
yeah maybe, if it doesn't sell as one lot. i would probably keep the manifold studs at that price though
datsunboy
aka: Dan
Post by datsunboy »
hey,
I said via PM that I was keen on the short shifter
please remove from trademe auction and sell to me 8-)
nzdatman
Post by nzdatman »
yeah and like I said I'd ideally like it all to go in one lot, so I'm going to try to do that, if it doesn't sell you'll have first option on the shifter. I'm just afraid that if i sell off all the good bits first I'll end up with a lot of shit I can't get rid of and have to take it all to the dump.
dat180
Regular
Post by dat180 »
Front sump on the CA's Morgan or are they rear sump?
Locked
