wanted to fit the s13 gearbox but i would need to move the motor 30mm forward and this causes all sorts of headaches that i cant be fucked fixing atm , so i fitted the s12 box back in should be sweet as im not running 200kw or anything.
brought a dropping resistor for it that had been modified with other resistors and solder , this pretty much made the resistor useless so i got one off a honda and fitted it
looked at the old de loom and decided that it just wasnt going to do so i spent a millions hours reading wiring diagrams and some net guides and hooked up a few relays for ignition and ecu power.
when fitting the engine mounts i found that the turbo wanted to be part of it so i cut a bit out of it , looks a bit rugged atm but i will be taking it out and strengthening and making it look nicer.
got the intercooler where i want it to sit ill get some 90deg bend welded onto the ends it will go through a couple holes ill cut on the rad mount , i might actually find a alloy radiator thats a bit smaller lengthwise to make it easier to fit the piping in + the top rad hose is on a gay angle and in the way of everything now the battery has been moved .
and last but not least a little vid clip , this is pretty much how it run when i first kicked it over super stoked at how its runs
