How do you make an A12 faster?
all your DIY needs
crustywhip
Datsun Addict
aka: Kane
Post by crustywhip »
Hi all
Im after some cheap easy options to make my current engine a bit faster. Im doing about 60+ kms per day which is mainly flat motor way driving except the ngauranga gorge with a grade of 8% (according to wiki)
Im happy to remove the head but cant afford head work so Im after the best ways to make driving each day more enjoyable.
Cheer
Kane
DylPhil7
aka: DylPhil
Re: How do you make an A12 faster?
Post by DylPhil7 »
a15 hahaha a12's are gutless
crustywhip
Datsun Addict
aka: Kane
DylPhil7 wrote:a15 hahaha a12's are gutless
If I found a good A15 cheap enough thats exactly what I would do. Money is tight again while I save so its making do with what I have for now.
braasmonkey
Site Admin
aka: Braasy
Post by braasmonkey »
Sadly cheap A15's requiring next to no work/money is not possible, I should know... I am in the process of re-powering my 1200 project car with an A15 which I can't wait to be complete. As silly as it sounds (and I know a lot of people forget), a simple tune up is the best and cheapest option. I don't know you or your car, so is all I could suggest for now... lol.
crustywhip
Datsun Addict
aka: Kane
Tune was done which made it a little better. I was thinking lighter fliwheel and a weber 32/36 from a ford escort as they are easy to find. I have also heard A15 heads fit. but would this make it better? I need to do some thing before Im over it and sell to fund some thing else.
LOWSTHEGO
Regular
Post by LOWSTHEGO »
If your serious about selling to fund something else I would be super keen on it if/ when I sell my bmw.
a14/15 head planed to increase compression ratio, careful you don't want to be limited to 98 fuel though. extractors. SU carbs. do you have a 5 speed?
Cheapest increase is advance your timing, that will show a small gain in power, but put the engine on the detonation danger zone, but running 98 will help with this.
Not a huge increase though, and could cost with a blown piston so can be expensive long term.
Even just planing your head and extractors would make a difference.
crustywhip
Datsun Addict
aka: Kane
classicdat wrote:a14/15 head planed to increase compression ratio, careful you don't want to be limited to 98 fuel though. extractors. SU carbs. do you have a 5 speed?
Il avoid the timing change as the distance I travel and look into a carb swap and headers to see how it goes. Even a slight increase will be nice.
DylPhil7
aka: DylPhil
Post by DylPhil7 »
i had a mini with a 1100cc it had a dellorto and extractors. i planned the head because it had a leak through the head gasket. however i didnt really feel much of an increase though... mini's are rawkus as tho
crustywhip
Datsun Addict
aka: Kane
I found the answer to making a A12 faster. Replace it :lol: . I won an auction for a 4age and box but still have not heard from seller. Kind of annoying as there was a sr20 and box for the same price. For now I have fitted my spare A12 with an A15 carb which is better but still a little slow.
