Hi guys,
I am after a Optical distributor from a 6 cylinder L-series engine.
I think these came on L20E's, and L28E(T)'s
anyone got a spare?
6cyl L-series Optical distributor
- aka: Dan
Re: 6cyl L-series Optical distributor
Are you particularly after an optical one or an electronic one?
- aka: Dan
particularly after an optical one.....
but....if you have an electronic one....could you take a pic of it's insides? I want to modify one, and the optical ones are the most likely to work with what I want to do
- Datsun Mad
Interesting im curious as to what you want to do.
- aka: Dan
I bet you are lol
you especially.....thats gotta give it away
- Datsun Mad
yip i figured as much.
Im working on mine now to well slowly kinda dummy fitting bits and pieces right now.
- aka: Dan
what are your plans to sort it out?
- Datsun Dreamer
- aka: 10 5
i have an electronic one, what do you want photos of in particular? replacing the electronic one with the optical one so i can run the megasquirt.
- aka: Dan
just want photo's inside of it with the cap and rotor off.....to see how all the insides are mounted
I suspect it wont work tho.....but worth a look
- R30 Guru
- Regular
- aka: Jordy
Hi there, I've got an optical dizzy if you still need 1 I've also modified 1 to use as a Crank/cam angle sensor to use with a wasted spark set up for my link.
Projects Under Development
83 HR30 GT L31ETT
82 HR30 GT VH45DET
67 A30 GLORIA 4DR SEDAN-Resto
http://www.jurassicautomotive.com/" onclick="window.open(this.href);return false;
http://www.facebook.com/JurassicAutomotive
