1200 coupe z18et project
z18et1200coupe
- aka: The shed
Re: 1200 coupe z18et project
haha almost burnt my car down today haha! good times! there was a loose power connection in the engine bay which i connected properly (it gave power to inside of car) and then it started smoking crazy and i quicky whipped a battery terminal off and by that time there was smoke eveywhere and quite a few wires had the insulation burnt off and were glowing red! i'll fix that up tomoro and then if everything still sucks arse im going to take it into the shop and get them to fix it!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1972 1200 coupe z18et
1979 Starlet Bugeye
1974 ke25 coupe
datsunboy
- aka: Dan
aw no! you let the smoke out
z18et1200coupe
- aka: The shed
i've given up on the wiring for the time being! im just on the search for a 1200 complete loom to transplant into my coupe! anyway today i got some paint and did my bonnet, it came out ok for my first real paint job on something! i will post pics later!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
datsunboy
- aka: Dan
if you really give up mate, send either loom down to me and I can sus them out for you
z18et1200coupe
- aka: The shed
i have send you a PM mate, i am super keen for some help! cheers!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
z18et1200coupe
- aka: The shed
have done a few little things of the last few days, primered the underside of the bonnet and bootlid, will primer door jams soon too. then i will paint all door jams and undersides of things then take it into the shop to get a good job done on the top of everything!
also the plan is to make a whole new loom now, i just need to try and find a place to buy 50m rolls or similar or wiring!
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
Dont buy one roll of wire!
If you use all one colour, fault finding in future will be IMPOSSIBLE.
z18et1200coupe
- aka: The shed
Bartman wrote:Dont buy one roll of wire!
haha dont worry mate, i will be labelling each wire, and having them labelled through chockblocks too. i found a rewire your car "how to" on the net and and it looks pretty good! cheers
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
datsunboy
- aka: Dan
PLEASE do not use a single chock block in your cars wiring at any point.z18et1200coupe wrote: having them labelled through chockblocks too
chocky blocks =
