Yeah I could stick the L16 sump and pickup on it.....but if im doing all that, I cant be bothered paying for gaskets and oil twice lol
I'lll just rebuild it, and bike lol
probably a combination of oil rings and valve stem seals....
Oil rings could rotate, so weren't seized, but they were pretty tight.
Valve stem seals had gone hard and brittle, so definitely would have been helping the smoking.
There was a wet patch of oil across the head gasket from one of the oil galleries to cylinder #4....but I cant be certain if the wet patch was there before I took the head off or not.
pistons #1 and #4 were both wet with oil, #2 and #3 were dry, but had carbon build up much the same as all pistons
A wee test you can do while the engine is running is after a down hill run, (on overrun, Throttle closed - engine breaking coming down hill) if it blows blue when you floor it the rings are gone, generally valve stem seals will give smoke after idling or sitting and opening the throttle, I'm hoping this is what is wrong with mine.
If the rings are shot you will often get 'oil wash' on the piston crown, the carbon around the edge looks to have been washed away leaving the piston clean and exposed. Sorry if this is common knowledge and I am preaching to the choir.
classicdat wrote:A wee test you can do while the engine is running is after a down hill run, (on overrun, Throttle closed - engine breaking coming down hill) if it blows blue when you floor it the rings are gone, generally valve stem seals will give smoke after idling or sitting and opening the throttle, I'm hoping this is what is wrong with mine.
I didn't know this ^, so you've taught at least one person something
explains why my piston tops were reasonably clean when i pulled head off lol ahhhhhhhh well bit of oil wash never hurt anyone but the environment and the pocket
