its got 77mm pistons, with only 1.5mm dishes, so would be quite High compression I imagine in the vicinity of 11.5:1
Bad news, I pulled the cracked #4 piston out, to find it had also lost one of the skirts on one side,
good news I found complete skirt in bottom of sump
bad news it had a friend
worse news, neither of the two skirts matched the #4 piston
nett result, 3 of the 4 pistons are broken!
Makes me wonder if there is something seriously wrong with the piston selection or original set up when engine was built.
The motor has only done minor work since being built (perhaps 10 or 12 club events).
so much for tracking down a single piston to suit and getting out of jail for cheap
Cracked piston
hmmm, spare skirts........
