Due to some stuff going on I'm considering selling my R30 coupe project, the build thread can be found here on Oldschool:
http://www.oldschool.co.nz/phpbb/viewto ... 17&t=23509
The car is now running well but not tuned on the Link G4 + 440cc GTR injectors, air flow meter has been removed. I am willing to including the Link computer with the car is for extra $1000.
63,000k red top RB20DET ex Z31 200ZR
R32 RB20DET sump
Battery relocated to boot in a battery box (not yet mounted)
Bosch 909 fuel pump
HKS EVC4 electronic boost controller & HKS turbo timer
Custom made fuel rail to suit top feed o ring injectors
Custom made leads, new wasted spark coil setup
New RPM performance 240mm clutch & lightened factory flywheel
New aluminium radiator & silicon hoses
New K&N filter
New electric adiator fan
600x300x76 Racepro intercooler
R31 clutch R200 LSD 3.7:1
New aluminium intercooler piping
Blow off valve (not fitted yet)
Rebuilt T3/4 (Z31 centre section & 0.63 exhaust, Turbonetics front end)
New 2.5" exhaust
New Momo wheel & bosskit
Modified 280ZX gearbox
Modified driveshaft by Circle Track Engineering
Comes with a dial gauge dash and R32 GTS-t rotors and calipers - not fitted.
It is now on standard suspension and Z31 300ZX mags. It will need a few more bits and pieces before it can be certed, drive shaft hoops etc and I would probably upgrade the brakes before trying, S13 coilovers are easy to fit.
HR30 RB20DET powered
Re: HR30 RB20DET powered
Talk to datman310. he might be able to get you a deal on powersteer hoses.
Thanks man. The Power Steering Shop is about 2 minutes away from my house, just haven't managed to get there yet. Work keeps getting in the way of working on my cars!
Hey man,
are you able to tell me the numbers on your AFM? I have a NICS red top in my C31 Laurel but I dont have the correct AFM, people keep giving me the one for the ECCS model.
Thanks.
Thanks.
** DRIFT MULISHA **
83 Nissan Laurel C31 ** Project **
91 V6 Pajero ** BUSH HACK/DAILY **
89 Mitsi ZR4 ** Project **
Hey, it's got on it:
22680 22P00
A36-000 J12
I've got one off a VG20ET Z31 that looks the same but it has this on it:
22680 12P00
A36-000 028
Hope that helps.
22680 22P00
A36-000 J12
22680 12P00
A36-000 028
Hope that helps.
Do you want to sell that z31 AFM?
If you do I might aswell give it a try and see if it does the job, have you tried it on yours?
Thanks
0211730522.
Thanks
0211730522.
** DRIFT MULISHA **
There's a guy on Trademe who has a NICS one, different numbers though - he said it was 22680 l6V00 A36-000 N60 9210D.
http://www.trademe.co.nz/a.aspx?id=368731854
Maybe try him first? I haven't tried the Z31 one on my car yet.
Yea I saw that one on there but that afm is for the eccs motor not the nics.
The wrecker I got my motor from might have one, if not ill pm you.
Thanks for the help.
** DRIFT MULISHA **
I'm bumping this just incase someone here is interested, I'm going to be returning it to standard if not sold very soon.
Would be interested in swapping for a 280ZX, Z31 or Z32 300ZX, maybe other 70s or 80s Datsun/Nissan or an Alfa Romeo 33 Permanent 4, GTV or 75. Cash either way if required.
