My 120y Coupe Project!
- DylPhil7
- aka: DylPhil
Re: My 120y Coupe Project!
That looks Dope!!!
- Newbie
thanks guys. progress will be put on hold for abit due to me being accepted in the army i leave in 4 days.
Dylan (dylPhil7) if you could ring my cell some time tomorrow or give me your home number to ring id like to sort out an arrangement with the motor before i leave.
- aka: The shed
me and corey whacking in joshs A15 today as he is down in chch for some army rubbish! got it going but she was running a bit rough, are A motors the same firing order as K motors? 1,3,4,2?
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1972 1200 coupe z18et
1979 Starlet Bugeye
1974 ke25 coupe
- aka: The shed
heres the photo...
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
- aka: The shed
yes the timing is set to about 8 but its running real rough, will probably have a good look at it tomoro and see if we can get it running right!classicdat wrote:Yes 1-3-4-2, 7-10 Degs advance vacuum off.
1976 NA Lancer
1979 Starlet Bugeye
1974 ke25 coupe
1979 Starlet Bugeye
1974 ke25 coupe
If carb has been exposed it may have a bit of muck in a jet. With aircleaner off and stud out of the middle, hold about 2500 revs on the engine and choke the carb by covering the inlet with your hand, try to remove your hand to allow the engine to recover.
- gingofthesouth
- aka: Ging
If thats Dyl's A15 it was running fine in the brown sunny it came out of. Prob just what classicdat said.
