Rust repair/maintenance is a go! **UPDATE #1**
Front guards removed to get a clear and complete idea of their condition. The right hand was not great (although advised repairable), but for the sake of $105 + GST for a new guard, went with the replacement option. Went through BE Car Parts here in Christchurch and also picked up a matching front left guard, bonnet, and grille. Pricing was as follows:
Code: 1619928-0 | Description: NISSAN B110 1200 UTE 1970-83, BONNET | $150.00 excl. GST ($172.50 incl. GST)
Code: 1619931-1 | Description: NISSAN B110 1200 UTE 1970-83, FRONT GUARD - L/H | $105.00 excl. GST ($120.75 incl. GST)
Code: 1619931-2 | Description: NISSAN B110 1200 UTE 1970-83, FRONT GUARD - R/H | $105.00 excl. GST ($120.75 incl. GST)
Code: 1619999-0 | Description: NISSAN B110 1200 UTE 1970-83, GRILLE - SILVER/DARK GREY | $65.00 excl. GST ($74.75 incl. GST)
Total = $425 excl. GST (488.75 incl. GST). Also given free delivery to Kaiapoi (where the car is being worked on presently).
Advised inner wheel housings and upper chassis rails looked to be in good shape (it is apparently common for them to rot out as water sits in the bottom of the rails). Also removed the crappy wing mirrors from the front doors. For now, the screw holes have been filled with urethane sealer (to make them water tight) until I get to painting.
Initial update images are as follows:
Further updates to come!
- Braasy
