WTB 4 port ca18de head
nick_m
Datsun Master
aka: Nick m
Re: WTB ca18de headers and carb manifold for carb setup
Post by nick_m »
its pretty close side draft is 90mm boire spacing CA is pretty close to that, can't recall off the top of my head
Thats all the one that brock sold was anyway. Pretty sure josh has/had a proper cast one.
datso
Post by datso »
Yes the oval holes are very close to a weber spacing.
Theres alot of work involved hence prefer the mani already done.
However It wont matter as I have another idea which is doing
the same but instead of weber flanges just 4 tubes welded on
after machining off the factory flange that meets the upper
manifold flange. This will allow my cbr1000 quad carbs to fit.
datso
Re: WTB 4 port ca18de head
Post by datso »
any 4 port heads out there?
datso
Post by datso »
still looking
Keep an eye on http://www.trademe.co.nz" onclick="window.open(this.href);return false;
They pop up there from time to time.
datso
Post by datso »
will do Bart, if you see any that come up and I miss it pls let me know :drool:
Should just fit 42mm inlet valves like yours, get 79mm bores, an autorotor fed by a 2inch SU and be done with it :tits:
TBH, I don't really know if the 42mm valves are worth the hassle first up. (Mine were already fitted to the head when I bought it) Just build a stout bottom end, blower friendly cam, and do skids. You can always add a high performance head later on down the track.
datso
Post by datso »
sounds like you got your head in the right place :D
surprising with all the spirits you have!
datso
Post by datso »
:tits: looking but no score yet
datso
Post by datso »
:tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits: :tits:
Scored a 4 port
thank you for your help Bart
Locked
