ALLOY 4pot calipers off an r32 gtst type m.
292x30mm rotors, surface rust but in good condition.
Brakes pads have about 7mm on them.
Selling as they dont fit behind my wheels, and I dont need to hoard them haha.
GTR brakes are slightly bigger at 296x30mm, but are highly sort after and more expensive.
Great upgrade over the smaller z32 300zx calipers with 280x30mm rotors.
100mm caliper bolt spacing.
$400.
Nissan 4pot front brake calipers and rotors
- mint16
- aka: Brendan
72 Datsun 1200 Wagon
Re: Nissan 4pot front brake calipers and rotors
What size wheels do you have ? the 4 pots fit underneath my 15" Z wheels, its close ( even with wheel spacers ) but they fit
nick_m
- aka: Nick m
I think he'll have the same problem I had. Outer two pistons foul the back of the wheel not the diamter of the wheel
i used a 20mm spacer to overcome that but a 10mm might do depending on wheel design
- mint16
- aka: Brendan
15x7 with +11 offset, the outer two pistons stick out from the wheel mounting surface of the disc too far, Id need to run at least 25mm spacers and the wheels are already close sitting outside the guard.
Im not a fan of spacers, so have found another set of calipers that may fit, no guarantees they will haha.
