H75 vs H89 heads
all your DIY needs
agallagher
Regular
H75 vs H89 heads
Post by agallagher »
Im building up a new engine for the wagon,a14 with f12 cam and sidedrafts etc all off my old wagon
Its got a h75 head thats been ported but i was wondering if it would be beter fitting a h89 head to it instead since ive heard theyre
better performance wise,im not sure so your opinions and veiws whould be great!
Re: H75 vs H89 heads
The H75 head has an open chamber. The H89 is more closed. (Although not as closed as an A12 head, it has a deeper roof)
Depending how ported your H75 is, you'd be better off with the H89. It May be able to have the H75 skimmed down to make it closed chamber. (I once heard someone say it could be done) but this may lead to the compression being bumped up too high, or (Given that you're going to run a big cam) cause some valve to piston clearance issues.
Tony_Whenua
Post by Tony_Whenua »
I’ve got two engines in the shed I am working on. These are the plans for each.
1) A14 with H75 head. Original cam and dellortos.
2) A12 with H89, street cam, head planed & running dellortos.
I have a 3rd A12 with G25 head (stock one originally in Ute). Will likely sell on.
Have I done this right or should I switch heads over?
