Improve handling over uneven surfaces due to changes in suspension geometry / height of spindle, shock etc.
Keep the Geometry correct so your lower control arms arent above the horizontal!
These also look flash as too!
I wasnt gonna pay US$175 to get a set from BProjects in Japan, and was about to get some custom made when I found a guy in the States who made up a set for me, and have now brought a couple of sets in for the masses.
Details:
75mm Bolt centres (Suit all 1200's and 120Y's)
25mm thick
6061 Grade Aluminium construction
CNC Machined (and I had them red Anodized as well)
Nice Quality, bolt straight in (although I had one strut bottom with a slightly daggy weld, that I had to give a quick lick with the dye grinder)
$125 per pair
or $135 with High Grade Correct length Cap screws, washers & nuts (haven't arrived yet)
$5 postage
PM me if you are keen = First in first served
