2 front and 2 rear wheels and tires as below, all wheels are 4 x 114.3mm stud pattern.
Front
Rims: 14" x 6.5" JJ , +7 offset
Tyre size:185/70/14 SAVA 70, tubeless steel belted radials. 6mm tread minimum depth.
Rear
Rims: 14" x 7" JJ , 0 offset
Tyre Size: 235/60/14 Firestone F-660, tubeless steel belted radials. 4.5mm tread minimum depth.
Rims are old, but still in good condition. Two of the center caps are the same, the other two are both slightly different.
$500
Im not on the forum too often so best way to get in contact would be PH or TXT 0210429697.
