Could someone tell me if this is an A series flywheel ? cheers Greg
272mm diameter 10mm bolt holes 25mm center hole
Is this an A series flywheel?
stedy sss
- Regular
- aka: Greg - Stedy
82 720 2WD
83 720 4WD
72 180B Coupe
73 160J Coupe
83 720 4WD
72 180B Coupe
73 160J Coupe
stedy sss
- Regular
- aka: Greg - Stedy
Re: A series flywheel?
was told it was an L series, but it's not. Its about 11.5 lbs
82 720 2WD
83 720 4WD
72 180B Coupe
73 160J Coupe
83 720 4WD
72 180B Coupe
73 160J Coupe
- 160jsss
see http://www.nzdatsun.com/forums/viewtopic.php?f=9&t=471" onclick="window.open(this.href);return false;
This is one I've had turned down but it's for a L16 L18 .
Your one looks like one for a L20 extra bolt hole
Violet - ??????
I'll have a closer look tomorrow, but has 6 bolt holes like A series, what diameter?
