so i fitted my old brakes and bled them all round and felt happy that i was going to have brakes that work properly again, jumped in the car to feel the pedal and found that its lighter than what my clutch is now! check all the brakes and couldnt find any leaks, re bled them again and still nothing. has new brake cylinders in the back and the original brakes which worked prior to me changing to the R31's and now im stumped.
if the master cylinder was faulty would fluid still come out each bled valve? only weird thing is everything worked fine until i put the 31's on then off agian
it does brake the tiniest bit but the pedal is on the floor when it does. no idea what to do now
Edit: oh i forgot to put up a pic of my new t-shirt which just arrived today
