1200 front brake upgrade s13 ? help needed
all your DIY needs
PeteSSS
aka: Pete
Post by PeteSSS »
hi want to upgrade my front brakes on my 1200 race car, reading a few articles is the s13 disc and calipers the easy upgrade to do ? running 1200 front strut, any help will be grateful cheers Pete
braasmonkey
Site Admin
aka: Braasy
Re: 1200 front brake upgrade s13 ? help needed
Post by braasmonkey »
PeteSSS wrote:hi want to upgrade my front brakes on my 1200 race car, reading a few articles is the s13 disc and calipers the easy upgrade to do ? running 1200 front strut, any help will be grateful cheers Pete
I'd be keen to know to. I managed to source a complete set of S13 front brake bits for $50, knowing this may be the go.
grant76
Datsun Nutter
Post by grant76 »
basic run down is
adaptor plate
machine hub down a couple of mm's until disc can slip over
longer wheel studs (from s13 etc)
all bolts together pretty easy. I've just used standard 1200 disc/drum master cylinder in both my upgrades, no mucking around with boosters etc. Upgrade works great
Some of the guys on here have some brackets or cad designs to get brackets, PM BArt, he'll point you in the right direction if he can't help I'm sure.
PeteSSS
aka: Pete
Post by PeteSSS »
thanks for the help guys will get hold of him cheers
