wanted 1982 bluebied 910 series longnose diff
wanted 1982 bluebied 910 series longnose diff need asap what have you got and how much??!!
I think the datsun will need the plates OMGWTF when its done
Re: wanted 1982 bluebied 910 series longnose diff
Is it CV, or uni joint rear end?
If it's a unijoint rear end, how are the input shafts secured into the diff? If they're held in by clips on the end of input shafts, then a subaru leone diff should work. I may know a guy who has a collection of these.
currently running a subaru lsd i just want an open so i can lock it for track days and uni joint not cv the axles were held in by a bolt thru the centre of the spline if that helps
I know a guy who has wrecked a shitload of subaru's if that helps? PM me if you want his number.
