No Longer Brock & Lisas 1200 Project
Re: Brock & Lisas 1200 Project
Poor old Brock was having a nightmare of a time trying to fit the FJ in so decided that if the firewall was getting chopped then he might as well go all-out and put something even more ridiculous in.
- gingofthesouth
- aka: Ging
awesome if its to small a hole put something bigger in
- brocky41
- aka: Brocky
Started to cut the firewall / gearbox tunnell up, trying to take largish sections out so they can be modified to go back in.
Have also purchased some new disks for the front - 290mm x 22 mm 4stud just need to find callipers to suit.
Having a bit of a clean up / out again so will get some pics up asap.
- Area Reps
- aka: shane
RB26DEtt ????
If you're starting go all the way, VK56DE, No compromise 1200!!!
- gingofthesouth
- aka: Ging
except handling and front/rear weight distribution and....classicdat wrote:If you're starting go all the way, VK56DE, No compromise 1200!!!
So that would be NO compromise then wouldn't it! Not even for those things you mentioned. I'm sure they're not important.
Nothing Wrong with a good old VG30
But then again I might say that mightn't I
- aka: Nick m
well your signature says it all really doesnt it james haha
