Bart was telling me it can be done but wasnt sure how easily it slots into place. Has anyone done this?
Thanks Andy.
Thickers 120y swaybar into a 1200?
Re: Thickers 120y swaybar into a 1200?
yep, just bolts in. Just need new bushes with 20mm hole (i got some superpro from supercheap) can use original mounting brackets, just make sure you get the dip in bar around the right way (also make sure its a b210 swaybar. not a b310 120y bar)
- brocky41
- aka: Brocky
You may need to lengthen your link rods - (im running 1600 ones in my y for the same reason) so the dip in the bar moves further away from the sump to clear the ca18. other than that its a huge improvment in a 1200
- aka: Nick m
wouldnt lengthening the links move it closer.
No they would lift the back of it up and push the front down giving a bit more clearance.
Thanks for the info guys
