hay there guys just thought id put my hand up for some advice quickly
im pretty much finished putting my s13 brakes on my ute but my 13" superlites hit the calipers on the inside spokes due to piss poor offsett so they fitt in gaurds
im quite keen to try some CHEVIOT HUSTLERS if someone knows of any that i could try?
if they hit a wee bit could always run bolt on spacers and 165 50 13 stretched tyres
just cant really see my wheels doing it
but anyone that knows what can work would be apreciated
wheels needed 4 1200 ute front 2 clear s13 calipers??
project_1200_ute
- Datsun Dreamer
Re: wheels needed 4 1200 ute front 2 clear s13 calipers??
I can do a set of 13x6 cheviot tridens, or a set of 13x5.5 (enkei?) tridens if you were interested?
Mayber your bigger discs are the problem?
I know for sure my 3x6 tridens clear my 250mm rotors. But not by heaps.
project_1200_ute
- Datsun Dreamer
might be worth a try bart dont think my bigger discs are the drama just mainly my wheels because my spokes atculy turn in past the hub of the wheel
You know where I am.
