WRCDAT b110 13b rotary rallycar
- kobyn
- Datsun Mad
Re: my project (datsun 1200 race/rally car)
thanks to all who voted on facebook wrc comp only 24hr left and still 50 likes behind so if u havnt yet do and share as well
- Lang Inder
got my like
2x1972 Datsun 1200 B110 Coupe
2x1982 Datsun 180sx
2x1982 Datsun 180sx
- kobyn
- Datsun Mad
Thanks dude only 17 behind now
braasmonkey
- aka: Braasy
13 nowkobyn wrote:Thanks dude only 17 behind now
- kobyn
- Datsun Mad
Small update got my new 5puk clutch and presure plate also had to get gearbox output shaft machined down and a custom gearbox mount made
Driveshaft yoke done and balanced
Just have to put oil in box and run the clutch in was told that it takes 700km? Also put mudflaps on the rear
- kobyn
- Datsun Mad
Some betta pics while up on lifter
- kobyn
- Datsun Mad
just scored my mates 13b bp motor come outta his 1200 ute along with all the extras like mounts,raidator,holly fuel pump exshst system and 48mm IDA and electronic dizzy . Will pull current engine out in a few weeks need to get wof while the street smart rotary is still in ,posted a vid below of car with current engine and some pic of the 144 kw 13b bp thats going in
http://youtu.be/LSDcRT_BV08" onclick="window.open(this.href);return false;
That'll be quite a handfull!
Will existing exhuast be the right length for the PP engine? I was lead to belive that ported motors were really fussy about the length of the pipes?
- kobyn
- Datsun Mad
I will be using the exhaust that came with motor cos motor is dyno to that. As I understand the longer u can keep two pipes b4 going to one the betta . I should really do some research on that tho .Bartman wrote:That'll be quite a handfull!
