just thought id mention how wrapped i am with my 5speed conversion so far
pretty easy conversion the crossmember i made come up awesome
ended up using the sunny crossmember center chopping the ends off and fabricating the rest out of 2mm steel to match dropped it down lower to give extactors a wee bit more clearance etc
reverse light switch was cut down and welded up and grind an edge off as to clear mint
BUT IM AFTER A DRAIN PLUG FOR THE BOTTOM OF THE GEARBOX????
can u still buy them new? must be the same as something, dont match 4speed ones or diff or gearboxes however
1200 ute 5speed sunny conversion
project_1200_ute
- Datsun Dreamer
project_1200_ute
- Datsun Dreamer
Re: 1200 ute 5speed sunny conversion
4speed diffs or 'engine sumps' i mean sorry
- mint16
- aka: Brendan
Ive got many sump plugs for gearboxs dude.
Can sort it this weekend if you want.
72 Datsun 1200 Wagon
project_1200_ute
- Datsun Dreamer
ive got the gearbox sitting in at the moe waiting for a shortshift kitt to try then itl be back out
but cheers dude i might aswel chuck the box in my van and drag it round so can try a few wouldnt you reckon?
project_1200_ute
- Datsun Dreamer
u might even be where that sump plug ended up although probs not
