Mutiny
Posts: 18 Joined: Sun May 27, 2012 9:23 pm
Post
by Mutiny » Fri Jun 01, 2012 2:45 pm
some of you may or may not have seen this on trade me.
motors siezed so on the look out for another. have started doing the rust, wasnt as bad as i first though
anyway heres some pics, will get some better ones when i can get it out of the garage
as you can see a 30 minute polish and it came out alot better
Datto_610
Posts: 2976 Joined: Sun Jul 20, 2008 10:39 am
aka: Greg
Post
by Datto_610 » Fri Jun 01, 2012 3:10 pm
This thing is so cool! What are your plans for it?
Mutiny
Post
by Mutiny » Fri Jun 01, 2012 4:38 pm
semi restore and lower, thats pretty much it, maybe full resto further down the track
Posts: 7303 Joined: Sat Jul 19, 2008 9:04 am
Post
by Bartman » Fri Jun 01, 2012 7:05 pm
Welcome Sam.
Very very cool car there.
2 doors
Posts: 2500 Joined: Sat Jul 19, 2008 6:26 pm
Post
by 2 doors » Fri Jun 01, 2012 8:27 pm
had this on my watch list, very cool car, was so tempted to bid, but timeing is all wrong for hoarding cars, good to see it on the forum, will be keeping an eye on your build thred.
Mutiny
Post
by Mutiny » Fri Jun 01, 2012 10:18 pm
Bartman wrote: Welcome Sam.
cheers bart, have always lurked, thought id sign up and give it a whirl, should be some good progress over the long weekend.
have done a bit to it allready, un siezed the brakes, almost ready to yank the motor out. have cut some rust etc
Post
by Bartman » Fri Jun 01, 2012 10:34 pm
maybe find out why the motpr nipped up? It'd be fucking cool to keep the original early series motor with matching numbers in a car this old and rare. If you wanna throw it on an engine stand, and perform an autopsy, let me know.
nzeder
Regular
Posts: 57 Joined: Sun Dec 07, 2008 11:12 pm
Post
by nzeder » Sat Jun 02, 2012 1:05 pm
Try and keep the original engine if possible - you can use later L6 parts inside to replace bits that are a bit beyond reco. Those engines were produced in very small numbers making way for the L24 just a year after these first appeared. If budget is a concern - just put a L24/26 in there for now while you strip the L23 and do it correctly - this engine needs to say with this car
But then it is your car so do with it as you like
76 RS30 260z road
73 RS30 260z track
Previous
70 HS30-00016 240z
72 HS30 240z 2.8 track
71 HS30 240z 3.2 road/track
79 HS130 280zx
82 HS130 280zx T top
2x 73 KP710 160JSSS
74 KB210 120Y Coupe
71 510 1600 Deluxe
fletch
Posts: 110 Joined: Thu Sep 15, 2011 10:57 pm
Post
by fletch » Sat Jun 02, 2012 9:09 pm
if you need any parts let me know. Im coming to nz next weekend and will have about 15kg of capacity
i might have some l23 parts left lurking about. Not manyparts from the later l24/26/28 will fit. the timing covers are different, the sump also.
Mutiny
Post
by Mutiny » Sun Jun 03, 2012 11:22 am
have you got one wrecking out?
