All parts are AS IS as a lot of it I haven't used. I have other parts that aren't listed, ask if there is something you're after. I'm not a wrecker, just trying to clear my garage.
S12 power steering rack
$40
S12 factory front lower control arms
$30
S12 FJ20ET crossmember. This is the taller type one. Currently sandblasted awaiting someone to spray it. Would recommend a good sand or sandblast again as it's getting surface rust.
$60
S12 front brake calipers and rotors - heaps of pad life left
$40
S14 factory castor rods
$20
S14 SR20DE ecu - have two, both different part numbers
$20
S15 brake booster and BM44 brake master cylinder.
$50
S15 non turbo front brake calipers and rotors.
$50
S15 interior loom includes dash loom
$50
SR20DE water neck - suit having water temp sensor thread put into it.
$10
SR20DE/T viscous fan - have two
$20
SR20DE/T alternator - unknown condition
$25
SR20DE/T power steer pump - non hicas
$25
SOLD:
S12 castor rods - pending payment/pickup
S12 castor rod brackets - pending payment/pickup
12" electric fans with alloy shroud - pending payment/pickup
