hi my name is mike im new to this site,but have been a datsun/nissan fan for years always owned one or to or three at a time,you guys wanted more picks of my car.so here is some that i have on hand.enjoy
1984 200zx turbo
vg20et auto soon to be changed to manual
have fitted new shocks and jamex superlow springs
2.5" exaust fitted from turbo back,tip soon to be changed
Last edited by southerndatsun on Sun Nov 11, 2012 10:43 pm, edited 2 times in total.
well not much has changed its been in storage as fuel injectors started to leak,have sourced some early low impedance vg30et white injectors.just got to get them to fit as thay have a diffrent return set up.and also got a air research vg30 turbo as well it has a bolt on wastegate on it.will get picks of injectors and turbo tomorow.
Thanks,i got to get picks of my dad who was the panelbeater and painter for the car of when we striped it down/out and tidyed up the body and repaird the cancer.but here is what i got the other day.
That looks like a VG30ET turbo, it's a good thing you got the type with the wastegate flapper in the middle piece rather than the ones built into the downpipe. Those injectors are crazy, look like some sort of early attempt at a top feed/side return system?
thanks skdmrx,not to sure yet want to get injectors sorted 1st,then manualise it.new rims in some time to as thay dont do much for it atm cant deside on what i want to put on it.yeah djz i think it is too but it is big and my mate that got it said it was defnitly off a dohc vg30det early as.
been busy with the other two projects this weekend got the r31 skyline running with the rb25det.also my newly narrowed hilux diff has finaly turnd up at my workshop for my sr20det cortina so ill be rebuilding the diff to get that back on the ground quick smart.just deciding on what wheels to get for the zx any ideas?
hi been a bit slack been driving the zx as my daily again after akaroa nats so havnt spent much time under the bonnet,appart from today when it had a major miss fire found number 2 lead had poped off plug so gave it a going over and cheakd plugs etc.also got a hold of a z32 manual car today for parts! got it for 2hundy has a major water leak around engine somwhere,but all im after is the gbox stuff and breaks and diff.so some upgrades will be posted up here.got some more build picks to put up tomorow.
