1200 sedan running very bad after coupe cluster upgrade
all your DIY needs
jas1200
Datsun Driver
aka: Jas
Post by jas1200 »
I need some help with this problem, ever since I rewired the plug for the coupe dash cluster, my 1200 has been running like s......t, its progressivly got worse, today it was undrivable, 5m down the road was a massive struggle. I put a new (second hand distributor cap on) and no diff but when I disconected the rev counter (from the possitive side of the coil)it ran fine....can anyone help out here?....Jas
buzzy
Datsun Driver
Re: 1200 sedan running very bad after coupe cluster upgrade
Post by buzzy »
pretty new to this but I have read that the tacho should go to the neg side of the coil? have you tired this?
jas1200
Datsun Driver
aka: Jas
Post by jas1200 »
Really, I wired it from some info I got off 1200.com......will try that tommorrow,....just checking but why do you say the negitive side?
buzzy
Datsun Driver
Post by buzzy »
I read it on 1200.com also?
Hopefully someone thats actually done the swap can help out as to what side of the coil it goes to.
datsunboy
aka: Dan
Post by datsunboy »
Yes, all tachos should be wired from the negative side
Blair
Datsun Nutter
Post by Blair »
I used this when I put the coupe dash in my 1200.
jas1200
Datsun Driver
aka: Jas
Post by jas1200 »
Negitive was a no go, somethings not right, i,ve now got smoke coming out of the distributor and it wont start at all....
Blair, I also used that wiring chart but most of the colours were different...I had do change most of the wires, all of the dash works but its not wired like that.
Blair
Datsun Nutter
Post by Blair »
Interesting. Got some pictures??
jas1200
Datsun Driver
aka: Jas
Post by jas1200 »
Hi Blair, what was it you wanted a picture of.....I have it all writen down as to how it wired.
buzzy
Datsun Driver
Post by buzzy »
Can you post a pic of what wires you put into the round plug? I have 2 wires that are different also an extra black wire and a yellow/black not yellow/blue and no red/yellow?
