conversion parts needed for b310 sunny.
- brocky41
- aka: Brocky
Re: conversion parts needed for b310 sunny.
Loving that many can help a little bit to get the job done - what a clubs all about - many thanks guys
Just let me know which drive shaft you need.
Cost $100 for all the bits. Plus freight.
There is a good amount of meat on the clutch, no burn marks on the flywheel or the pressure plate.
crustywhip
- Datsun Addict
- aka: Kane
Have you tried Tony (flauski) he has wrecked a few of these so no doubt will have some thing to add.
- brocky41
- aka: Brocky
Hi guys thanks to all that are helping with this,
I still need A12 4 speed Gear stick (any shape bent or straight) and a 1200 Clutch Cable with the small end and small bit that stops inside the gearbox bell-housing. (basically B110 one)
Cheers Brock
Cheers Brock
damn i have 2 clutch cables you could have, but they are in storage, and under a heap of other crap, if i was in town id dig them out for you.
- EMs SR1200 UTE
- Regular
Hey, I was scratching around in my ute parts the other day and I found a clutch cable.brocky41 wrote:Hi guys thanks to all that are helping with this,
Cheers Brock
Make an offer and I will get it sent to you if you still need one.
I can look for a gearstick aswell as when we sold the original engine and box im sure the gearstick didnt go with it.
S13 SR20 Datsun Roadster Ute
