Hi chaps,
Question: what struts have the part number:
NISS
54302 8800
9524
AT5UU
JAPAN
I have just removed them as I have found the springs were cut and will need to replace them and mod the strut. They were fitted to my Datto 1200 sedan. 1972.
They have larger brakes than my other 1200's.
Any help would be great.
Nissan Struts?
Nissan Struts?
Find out if the wheel bearing are bigger if so you probably have 120y or early b310 struts what dive are your discs ?
- R18dat
- Regular
Re: Nissan Struts?
Cheers Chris,
I have found some infomation pointing in the direction of B310 struts, but still nothing concrete. I have just measured outside diameter of the strut and is 51mm, big difference from the 1200's strut of OD. 45mm. From here I will buy new springs, shocks and shorten struts.
Cheers for help.
Cheers for help.
