swapped my van for a 1983 910 bluebird. has stock L20b but with twin su carbs. got 117000km on it with a mint interior. came with some cutties which are captive and an LSD. plans are to throw some wheels on it, 2.5" exhaust, give it a tune, tidy up the paint and get the carbs running properly.
just a few pics.
did a bit of work on the old bluebird. fitted some plugs and leads as well as a shiny new oil catch can and man what a difference. will fit some points and check the timing as well as balance the carbs when time and money allows.
also painted the bonnet black after a failed attempt at a cut and polish. decided to paint below the door trims as well just to tidy everything up a bit and to give the car a lower looking stance. paint came out a bit shitty in some places with a bit of orange peel effect going on.
got a shiny muff fitted to my beast and damn its loud!!! :tops: has a straight through pipe to large tip and its mean as.
finally got it legal today after failing my warrant on cut springs and a bald tyre. once funds allow for it the cutties will be going back in and i will shorten the struts to make everything captive.
its alot more level that last time but still too high.
just was mucking round and found my old japanese automobile federation badge, so i fitted it for that little bit of JDM goodness.
