vg20et
southerndatsun
Regular
vg20et
Post by southerndatsun »
hi what is the static timming for a vg20et?
just want to double cheak somthing.chears any help be nice
85_Z31
Datsun Master
Re: vg20et
Post by 85_Z31 »
If it helps mike the base timing on my VG30 is 20deg, the crank pulley has marks from 0-30 deg on mine.
Hopefully that helps, once base timing is set ECU sorts out the rest.
torqued
aka: Adam
Re: vg20et
Post by torqued »
15 (-+2) @700RPM
southerndatsun
Regular
Re: vg20et
thanks guys yup was out a lill off the marks (almost 20mm past marks) when i put my timming light on it!!! so its been ajusted back to where it should be it going good again.thanks for the info :thumbsup:
