Was charged $2500 odd for the heat pump and $980 for the Installation
After the installation I was shocked to find some obvious issues..
Firstly the unit is HUUUGE - the brochure does not show the true size of the unit and I would not have OK'ed to put it in such a blatantly obvious place
brochure - http://www.panasonic.co.nz/heatpumps/he ... 18hkr.html
Without asking they pulled out 2 shrubs which we had nicely growing.
Now I can no longer open the french doors all the way open
Even though the hook to hold the door back is obviously right there behind the wiring/plumbing
The power conduit is run along the ground and is mounted at 1200mm gaps so the conduit can move around fairly freely
They damaged the gib around the power point that they branched the power from and tried to hide it by putting the cat house in front of it
I would have much preferred if they had put it here - it is much more discreet and nowhere near the french doors.
Am I being unreasonable?
I won't name the company responsible as the agent is coming over tommorow to take a look and may put it right, but his sarcasm and the way he has talked to me the last 2 days make me believe he ain't going to do diddly squat for me...
ARGH Anger does not begin to desribe my feeling right now.....
